Results 1 to 7 of 7
Thread: PH Bounce
    PH Bounce
    PH was 7.4 for the last week and I've been trying half heartedly to raise it without raising my TA so I aerated for a day and got it up .2 ish. Today I aerated again for maybe four hours but also threw in a box of Mule about 2-3 hours ago as per the pool calculator. I just checked it and it's showing a PH of 8. I've stopped aerating. Is there a natural spike when aerating? The acid demand test was 1 drop to bring it down to 7.8 . I can of course use some dry acid but don't want to chase it back and forth. We've had a lot of rain lately and t-storms are in the forecast and Toronto gets acid rain. Any advice / comments?
    FC 5.5
    CC 0
    TA Was 140 Now 130
    CH 140
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    22,553
    Re: PH Bounce
    What are you trying to accomplish? If your pH is rising just lower it with acid each time it gets to 7.8 and let the TA come down.
    Re: PH Bounce
    That's ok don't worry about it, I'll figure it out.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: PH Bounce
    You only need to add Borax to raise pH. Now that you've jacked it way up, you're going to need to add acid to get it back down.
    I prefer to just aerate to raise pH. It's cheaper.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH Bounce
    Quote Originally Posted by Durhamhouses
    If you will just let us know what you want to do, someone here can help you and be more than happy to help you figure it out!
    You're done SLAMing when:
    Re: PH Bounce
    No problem ..I thought I was clear in the desire to raise the PH to 7.8 without raising the TA ...now that I'm at 8 (overshot) do I wait to let the prevailing conditions (acid rain) bring it down or add acid now and then have to raise it again when it goes lower on it's own. In other words how bad is it to have a PH of 8 short term ..and was it caused by testing while aerating which I now know is no. I didn't have all the proper values plugged into the calculator. I swam it felt good I'm not worried about scaling so I'm going to wait before doing anything more. Sometimes you don't know what you "want to do" hence the question. But again thanks for the help I don't mean to sound cross.
    Feb 2008
    Denton, TX
    5,061
    Re: PH Bounce
    Go ahead and add acid to lower it back down.
