Thread: How Do I fix Skimmer/Drain Suction Problems?
    May 2011
    Herndon, VA
    6
    Hi Everyone,
    I am a new pool owner. I have successfully opened my pool and cleaned up what used to be a green swamp and made it into a nice clear inviting pool. Yesterday was my first time in the pool and decided I would go around to all of the skimmers and drains and check out their suction. I have 2 surface skimmers, 1 spa drain and 2 main pool drains (one in the shallow end one in the deep end.
    Here's what I found:
    Skimmer furthest from the pump had decent suction.
    Skimmer closest to the pump had about half the suction of the other skimmer.
    Spa drain (closest drain to the pump) had very good suction, the best out off all of the skimmers/drains.
    Shallow end drain had decent suction after I forced some water down there with a hose.
    Deep end drain had no suction even after trying to clear pipe with hose water.
    In an ideal world I'd think that all of the skimmers/drains should have good suction. How should I go about evening out or fixing suction problems?
    Thanks for any feedback.
    My Goal is Crystal Clear....
    18,000 Gal, IG, plaster, attached spa
    Jandy Sand Filter with Zeolite
    Polaris Pool cleaner
    1.5 HP pump with Polaris booster pump
    22,553
    Re: How Do I fix Skimmer/Drain Suction Problems?
    You either need valves for each or diverters in each skimmer. Or both. Take some pics of the equipment and post them as we might be able to give some advice.
    It's not unusual to not feel much suction, if any, at the main drain.
    Aug 2010
    Dallas, TX
    4,052
    Funny, you just answered a question I had in another post! I'm assuming if I have 1 skimmer and 1 main drain, I can stop the skimmer and then possibly feel something at the main drain?
    Insomnix's Avatar
    May 2011
    42
    Just to note. The main drain is specifically designed not to create a large suction for safety reasons. But if you were to bring, say, some pH dye down there and squeeze by the drain, you'd see how fast it is sucking it in.
    May 2011
    Herndon, VA
    6
    So this is a fairly typical situation?
    I'll take some pics and post them up this evening.
    I'll also try the dye trick and see what happens.
    Thanks for the responses.
