Results 1 to 10 of 10
Thread: Shelf life of TF100 testers
    Jul 2007
    Maryland
    89
    I've had my full kit for over three years and have only purchased the chlorine tester (stored at 72 degrees). I recently used the Calcium test, nd while the solution didn't mix well, the color changed as expected. Is it time for new testers?
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Re: Shelf life of TF100 testers
    Taylor says to replace everything once a year, but in practice the reagents usually last much longer, especially if they have been carefully stored. The first things to go bad are the indicator dyes. Watch to see if they stain the plastic bottle. If they do they are bad.
    Jul 2007
    Maryland
    89
    Thanks Jason. When I add the R-0012 regant as the final step in the CH test, it looks "curdled," but the mixture does turn blue. I don't recall if that happened when I first got it. What say you?
    c ya, grivera
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Is your reagent in an original Taylor bottle with a batch number, such as 2082C, printed on it? If so, you can phone Taylor Technologies and they can tell you if your reagents are Fresh, Usable, or if they need to be replaced. Of course, this has to do with age only; proper storage and handling assumed.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Aug 2009
    SW Wisconsin
    518
    grivera....my CH test has ALWAYS done the "curdled" blue look when changing back from pink to blue since it was brand new..so I don't think that's an issue...at least I hope not..as mine has done that for over a year now.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jul 2007
    Maryland
    89
    Quote Originally Posted by Lana537
    Lana
    Mine is in a plain clear generic bottle with a white label- no batch number. Always stored at room temp on top of my china cabinet- not in direct light
    c ya, grivera
    Jul 2007
    Maryland
    89
    Quote Originally Posted by flyweed
    Dan
    thanks for the reassurance...
    c ya, grivera
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Sorry for bringing up an old thread....but it's better than starting a new one if I can find my answer.
    I'm going to switch from Baquacil to BBB at the end of the season, and am going to buy the test kit to help me out. I'm kinda concerned about buying a $70 kit just for the switch however. What tips can you give me to at least be able to use the kit next summer as well, or should I be worried and just hold off on this purchase??
    Thanks again.......
    22,550
    If you switch from Baq to BBB you'll be able to use your kit next year to maintain your pool. In fact, switching from Baq, I recommend the TF-100 with the XL option and the SpeedStir. You'll be testing a lot during the conversion and you'll need the extra reagents. You're going to need a good test kit whenever you switch not only for the conversion but for the maintenance afterward. Consider it an investment. You'll spend a good bit on the kit but it'll save you hundreds on pool store chems.
    I have managed with a partial refill in the second year and then a full refill the third year.
