Thread: help with new hayward ec75a
    just got rid of star-clear cartridge filter to new Hayward EC75A perflex D.E. and filter seems to be functioning properly, just one question. When I stop filter and function bump handle to regenerate D.E. and restart filter it appears that D.E. is coming out of return for about 30 seconds or so before clearing up. is this normal? am I missing something? Filter defective? any insight would be greatly appreciated
    Roob
    16x36 igp
    35,000 gal., 48 sq ft DE Filter, IG Plaster, I don't know my pump size or flow.
    Attached Spa with waterfall overflow into pool. Hand vacuumed and maintained by me.
    Re: help with new hayward ec75a
    Welcome to TFP!
    DE should not come out of the returns ever, but you might get a small cloud of extremely fine dust. If you have a multi-port valve you can avoid this by running on rinse for 30 seconds before switching to filter. If you don't have a multi-port valve there is no way to completely avoid this.
    Thanks much for the info, pool is becoming clearer so it must be working, once its crystal clear I think I will do a complete cleaning of the filter and check the internals. The water is clean but lots of sediment (used the porous looplock over the winter, big mistake)
    It happens with mine but I think it is just gunk that gets through when you bump it.
    32k Gallon Vinyl IG, Hayward 75 DE, 1 HP, Chlorine. 4 top skimmers, 1 bottom skimmer. 2 top returns, 1 bottom return.
