Results 1 to 8 of 8
Thread: low ph
    hawkeye's Avatar
    davenport,iowa
    118
    low ph
    sorry this question may have be asked before but search tab isnt working,i just opened my pool yesterday and my ph is really low @ 6.9 so i put in enough chlorine to bring it up to 15 fc to shock and put in about 1 lb of cya, what else should i do? get some borax in it? should i just run filter 24/7 wait for clearing then stay on shocking until overnight fc loss is complete? any info would be great....mike
    fc 1.0
    cc 0.0
    ph 6.8-7.0
    cya 10 or lower
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Butterfly's Avatar
    South Carolina
    10,045
    Re: low ph
    Yes, use borax and get your pH around 7.4 ish ASAP.
    You're done SLAMing when:
    Re: low ph
    Do you have a TA test result?
    hawkeye's Avatar
    davenport,iowa
    118
    Re: low ph
    jason i ran out of daylight light last night to do ta test, i will do as soon as i get home form work and will post full results then thank you.....
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    hawkeye's Avatar
    davenport,iowa
    118
    Re: low ph
    I tested this morning before i added chlorine, and was running late so i didnt test for ch or cya but i added cya 2 days ago it should be around 40-50 range when it settles in sytem.How long should i wait to backwash the filter? I got my wife going to get some borax today and she will add it today...What do i want my ideal target ph level to be at again?
    fc 9.5
    cc 0.5
    ph 6.9
    ta 110
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    Aug 2010
    Dallas, TX
    4,052
    Re: low ph
    What is your filter's operating pressure after a backwash? Add 8 or so psi to that, and that's when you backwash. You can go up to 10 psi if you've recently added CYA and don't want to wash it back out just yet.
    It sounds too late, but I wouldn't add any more CYA until after you complete the shock process.
    I keep my pH around 7.6, but 7.5 to 7.8 range is fine.
    Re: low ph
    Get the PH up to at least 7.2 soon. I wouldn't raise it much above that, as it will tend to drift up to where it ought to be on it's own.
    I would raise CYA up to between 30 and 50 now, or soon. With CYA very low, you loose all of your chlorine to sunlight each day, which makes maintaining an FC level much more difficult.
    Aug 2010
    Dallas, TX
    4,052
    Re: low ph
    I edited my post for clarity, I meant to say "any more CYA" since he said he should be around 40 now. It'll take some time for you to know for sure, and you don't want to overshoot it.
