Thread: Average run time Intex SWG
    May 2011
    SE Louisiana
    9
    Trying to find out how long people are having to run an Intex SWG to maintain FC levels. My pool is 8400 gallons. I live in in SE Louisiana. Temps have been around 90+ degrees. Pools receives full sunlight for the majority of the day. I am currently running the SWG 7 hours a day. Still seem to be losing ~0.5 FC over a 24 hour period. I have been using small amounts of bleach every couple of days to compensate for the FC loss. I have the newer Intex SWG with copper adding. The copper adding cell is disconnected.
    Latest test results:
    PH- 7.5
    FC- 3.0
    CC- <0.5 sample only has faintest hint of pink after adding R0003
    TA- 80
    CYA- 60-65
    Water temp 85°
    12' x 24' Intex AG 8403 gallons, Intex model SF15110 sand filter pump, Intex SWG, TF100 test kit, Pool Rover Jr.
    Re: Average run time Intex SWG
    You should do an overnight FC loss test, description in Pool School, to check to see if you have a low level algae problem.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ditto...7 hours seems too long. We run ours 2-3 hours a day on a 13K gal pool (cya @60), but it is the older model w/o the copper feature and apparently produces more chlorine. I'm only guessing, but 3-4 hours should do it
    May 2011
    SE Louisiana
    9
    Yesterday I used bleach to increase the FC to 5 before the SWG started for its 7 hour cycle. While the SWG was running I took a sample of the water coming from the the return by placing sample tube in front of return and FC measured 8. I tried to perform overnight FC loss test. Sample taken last night after dark indicated FC of 4. Sample this morning indicated FC of 3 ppm. I slept a little late and sun was already up somewhat. CC during each sample was less than 0.5 after adding R-0003 the sample only a hint of a pink tint. Water in pool is clear.
    Am I going to have to shock the pool? The CYA/chlorine chart shows I will need a shock level between 24-28.
    22,553
    The OCLT doesn't indicate the need for shock. My sig has the requirements for passing the OCLT.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Just to add, the newer Intex SWG produces 12 grams/hr chlorine, the older model makes 24 grams/hr. I run mine for 6 hours/day, and I have a newer model with the copper ionizer removed. See my signature for pool size.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
