Thread: SWG pros and cons
    hawkeye's Avatar
    davenport,iowa
    118
    SWG pros and cons
    I have been looking into getting a swg for the pool,and my lps guy always tells me that its too hard on equipment and i only spend 50.00-60.00 on chlorine a summer so he wouldnt suggest installing one on my pool,and when i ask him why he says "it eats the pool sides and rails away and has seen lots of damage they can cause" so i always wimp out is there any truth to this statement? i finally got to open my pool yesterday!!
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Re: SWG pros and cons
    Problems with corrosion are extremely rare. There is really only a problem if you have some of the softer kinds of natural stonework. For most people a SWG comes out about even with what they would be spending on chlorine otherwise. Still, if your chlorine costs really are that low, then it will cost more to get a SWG. A SWG is very very convenient and the vast majority of the people who get one are very happy they did and would never go back.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Exactly what Jason said. We used only chlorine products with our old pool and are on the 5th year using salt in this pool. We replaced the liner last spring and inspected for rust, it was no different than the amount of wear n tear, rust or corrosion we had with chlorine only. What IS different is how much less work we do since the swg does the adding automatically. Up front cost, after that just top off salt in the spring
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Oct 2010
    Houston, TX
    152
    +1 on never going back, at least on my pool. unfortunately bought a house with a separate spa with a flagstone waterfall and can't use SWG there, but really really really wish I could, b/c it is so much more a pain in the rear than the pool.
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    Pasadena, MD
    12
    I love my SWCG. Would not consider going back. I have several neighbors who chlorinate using tablets, and they always seem to work harder at maintaining their pool than I do. Not that I neglect mine, it just needs less fiddling around now that I have the water balanced.
    There are some differences in the way you should balance your levels with a SWCG, but once you have it locked in, it truly is less work. See the following link for more info: http://www.troublefreepool.com/pool-...ater_generator
    You can get a CompuPool unit for around $500-$600 and if you're fairly handy, they can be installed without hiring a pool guy.
    Good Luck!
    Doug in Pasadena, MD
    21000 gallons
    Concrete/Plaster
    Aquapure SWCG system
    Pool owner since 2007
