Thread: Newbie here. Forgive my ignorance
    What is the best way and or most cost effective way to lower my ph? My neighbors use muriatic acid from home depot. $11 for 2 gal. But I noticed there are some powder forms out there as well. Is one better than the other? If it matters. We have a 20k gal ig pool with krystalkrete finish. Everything new last fall incase something is safer on new plaster
    Thanks in advance
    18,000 gal ig salt pool krystalkrete plaster 7x10 raised spa w/ 2 spillovers
    4x20 wet deck, waterfall, 17ft infinity edge, deck jets, nexxus lighting
    Jandy pumps & controls, Aquapalm PDA, 400k heater, Kleen Machine robot
    (6) 4x12 solar panels, clear solar cover
    Feb 2008
    Denton, TX
    5,061
    Re: Newbie here. Forgive my ignorance
    Muriatic acid is the most economical and efficient way of lowering your pH. The powders that are available out there are considerably more expensive ounce per ounce and add extras in the pool that may not be so good for the water or pool surfaces over time. The large majority of folks here use muriatic acid for pH lowering purposes.
    thanks a ton!!!
