My VS 3050 for my waterfall decides not to work on this beautiful Memorial Day when the kids go for a swim. It's been working fine ever since we had it, til now.
At the indoor control panel, when I push the button for the waterfall to come on, the LED lights up as it should but the pump doesn't come on. Going through the menu at the indoor control panel it says Intelliflo Status: No Communication
So I go outside to check the communication cable from the pump to the Intellitouch Center. The connector at the pump seems to be on tight and the cables in the load center is screwed in tight. The breaker is on, but I turned it off and on again just to reset it. But the green LED on the pump's control panel is off, but it should be on if the breaker is on. If I press the start stop buttons, no LED's come on. It should be green for on and red for off. But I get no light at all. I haven't had a chance to check for voltage at the breaker or at the pump. Hopefully I can check that tomorrow.
Anyone experienced this before?
