Results 1 to 7 of 7
Thread: Cloudy water coming out after backwash
    Is this common after doing a backwash and Rinse... it happens only for like 3-4 secs then water after that is crystal clear....
    Jun 2007
    TEXAS
    16
    You might get a better answer from someone more knowledgeable.....but if I don't rinse after backwashing, cloudy water comes out of the jets. I always rinse until I see the water is clear....sometimes that takes 30 seconds, other times it can take 2 minutes.....
    Yeah I should have waited longer I guess for it to clear up before I do a rinse...vice versa..
    Jun 2007
    TEXAS
    16
    Maybe I'm not understanding your post. When I finish backwashing, I then rinse. While rinsing I can see the water going through a clear glass....the water going through that glass is cloudy and then when rinsed good, the water turns clear. Once I see the clear water, I set the pump back to "filter"...if I've misunderstood you, I sincerely apologize.
    What kind of filter do you have?
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Something I learned here about the backwash/rinse cycle and which has made a big difference, is:
    1. Set to backwash. Catch some waste water in a white container (I use a white plastic pitcher). When the waste water is clean set to rinse.
    2. Rinse for 30 seconds.
    3. Do another backwash is you have plenty of water in the pool. I do this after a good rain when water is free.
    4. Rinse again for 30 seconds.
    You need to do the rinse cycle immediately after a backwash. It's part of the backwash process.
    Anna
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Jun 2007
    TEXAS
    16
    Jasonlion
    I have a Purex Triton Tagelus
