Thread: leaking under the epoxy
    Apr 2010
    Central NJ
    227
    I have found a leak from underneath some old epoxy in one of my skimmers, which is about quarter inch from the piping. Can I just epoxy the edge of the old epoxy? I'm concerned of having epoxy so close to the piping, is this a valid concern? Should I have remove the old epoxy and re-apply the new epoxy?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Mar 2011
    441
    Re: leaking under the epoxy
    You almost always want to remove the old epoxy then re-apply.
    20X40 30,000 gallon gunite pool
    Apr 2010
    Central NJ
    227
    Any suggestions on how to remove the old epoxy?
    Often you can scrape it off.
