Results 1 to 8 of 8
Thread: On the fence of a swg looking at a Goldine Aquatrol Salt Chl
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Looking at this model. Goldine Aquatrol Salt Chlorinator Above-Ground Pools up to 18k gal. 115v (AQ-TROL-RJ)
    I want to add it inline of my system. I will hard pipe my pvc when my new heater arrives. Is this plug and play? No hidden you need a cell for this too?
    Thanks much
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Re: On the fence of a swg looking at a Goldine Aquatrol Salt
    If you want to mount the cell in-line, get the AQ-Trol-HP. The RJ model is for mounting directly to the return fitting. Both of those include the control box and the cell and use standard plugs. There is a different version, append -TL, that works with twist lock plugs.
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    I bought the Aquatrol RJ, the return jet option. No surprises, no hidden options. It mounts vertically directly to the return jet & installs very easily. It doesn't have a flow switch, nor does it need one. I've had mine running for about a week & so far I really like it. Just wish I'd installed it years earlier. Check in the Lifetime supporters section. There's a supplier that will give you a discount. Look for the SWCG thread for the Aquatrol. Email them & they should get right back to you. Mine was $419 with free shipping.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We put in the IG version, bigger cell. Love it.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2010
    Michigan
    181
    Thanks all, I ordered and read the ps about this. I don't see anywhere about copper. Do i have to remove all copper before running it? I plan on doing multiple small changes like say 1/8th at a time 3-4 times this summer then a 1/4 at pool closing and 1/4 to 1/3 at next years opening
    Mar 2010
    Michigan
    181
    BTW my copper is 4 ppm, I am doing a small WC as i type.
    Mar 2010
    Michigan
    181
    Anybody know about the copper? I am still removing green,blue stuff from the water column. I flocced yesterday and vacced today, Will do this a couple more times and it should be gone by monday. Just have the copper to contend with. Done with changing about 8 inches of water and will do waterchanges bi weekly.
    The SWCG will be here monday and i'll install it friday or saturday.
    Mar 2010
    Michigan
    181
    never mind copper is about 1 ppm now. Found some salt test strips.
