Results 1 to 9 of 9
Thread: Coping and concrete issues... not too sure what to do
    Ottawa, ON, Canada
    153
    My pool was installed in the fall of 2009 and I live in Ottawa where it gets **** cold in the winter so frost is an issue. As expected, I had a few cracks in my concrete that appeared last year and a bit of spalling here and there, one spot was near the shed so not a big deal (wasn't broom finished, it was smooth finish in that area so I'll blame it on that) and a tiny bit of spalling elsewere but it stopped. This year however I've noticed this:
    - big deep crack with a chunk that came out.
    - the coping that isn't attached to the concrete anymore, in the same spot where that crack appeared.
    My main concern is how do I fix that so it doesn't get any worse with water getting in there and then freezing thus expanding the crack? My pool is still under warranty until the end of summer so I want the pool builder to fix it but after the rust on the diving board fiasco with him (and the excellent idea of a bedliner spray on it to protect it), I figured that I'll obtain the proper way of fixing it and then simply telling him. I'm thinking some kind of epoxy injection would be the way to do it but there may be something better out there.
    Would sealing the concrete also help with this ? (ie: it would repel water)
    I have an idea on what could have caused this: In the fall they blasted for days at the end of my street (200' away) to extend the street, I was ****** that they didn't do that earlier but I don't know for sure if that's the culprit. I doubt I have any kind of against them plus, there was a hairline crack where that big crack appeared.
    As usual, thanks a lot to all of you folks who make this forum happen.
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    Ottawa, ON, Canada
    153
    Re: Concrete issues... not too sure what to do
    <taps microphone> hello? anyone here? <taps microphone>
    :P
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by mart242
    Please be patient. When someone with the expertise to answer your question logs in, they will see your post and answer your question as they are able.
    Ottawa, ON, Canada
    153
    Quote Originally Posted by 257WbyMag
    Yeah I know but since we're in pool opening season my post was falling at the bottom of the list so I figured that a bump wouldn't hurt. A bit premature maybe but the part of me that worries about stuff wants to know how to deal with it to simply put it behind me.
    The pool was nice today however, the kids sure really like it! Crystal clear water thanks to pool school!
    Ottawa, ON, Canada
    153
    Re: Coping and concrete issues... not too sure what to do
    Final bump just in case anyone has any recommendations..
    Sorry I can't offer any assistance but I figured I'd bump you back up since you live within an hour of my place and you need an answer.
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Apr 2009
    Burlington, ON, Canada
    344
    Sorry can't help you with the concrete problem (maybe look to a company that does concrete driveways for advice??)
    Regarding your ladder, if he was talking about something like LineX ( http://www.linex.com/ ), that stuff is indestructible. They mention several times about salt water resistance. The place I get my vehicle rustproofed at (Krown rustproofing in Burlington, ON) deals with this stuff and I know it's highly recommended for bedliners. Not sure what your ladder problem is, but weirdly, something like LineX might work.
    Totally off topic, I wonder if you could line a pool with this stuff?
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Jul 2009
    London and France
    574
    No one? must fear litigation
    Crack stitching varies a bit but is essentially the same process. Open up the crack wide enough to get the epoxy in with enough mass to hold and cut perpendicular cuts to the crack and lay in stainless steel ties (twisted looking things)
    Found this whilst looking for picture to show you, quite a substantial looking thing.
    http://www.torque-lock.com/
    Ottawa, ON, Canada
    153
    Thanks for the torque lock thingy, maybe it could be part of the solution I need.
    The pool builder sent a guy yesterday and he agreed that just patching the crack may not last long. He said that something like rubber / epoxy coating may be better since it will never crack but my concern is that even if it doesn't crack I may end up with an uneven deck because parts of it are sinking.
    My pool is vinyl w/ steel walls and "Z" brackets that hold the deck. Well, they are supposed to hold it..
