Thread: need a little chem help (or reassurance)
    Aug 2009
    SW Wisconsin
    518
    Hey all,
    I cannot believe June is almost here, and I am STILL looking at my leaf and winter covers on my pool! May has been so dang cold, rainy and dreary we have had NO motivation to open it up yet.....until today. I pumped all the winter and rain YUCK water off the cover, and took off the leaf net.
    I loosened the winter cover cable, and grabbed a sample of the water in the pool
    Here's my numbers....I just wanted to run by you guys, to make sure I'll be adding the correct amount of stuff.
    First..my pool holds 25,600 gallons (33 foot diameter AGP)
    Temp: 64F
    FC: 0 (test sample didn't even turn pink when I added the powder) So I need to add 159 oz of 6% bleach
    pH: 6.8 (I am only going to raise it up to 7.0 because I still want to lower my TA a bit yet)
    TA: 140 ppm
    CH: 120
    CYA: 48
    Salt Level: 4,670 ( I have a SWG that calls for 5600ppm)So I need to add 5 bags of salt
    Please take a look at my number and let me know if I missed anything, or my numbers aren't right. I have the pool calc on my Ipod Touch and did all the calculations on it.
    Thanks
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    30,424
    Re: need a little chem help (or reassurance)
    Hey, Dan,
    Did you run the pump for a while before pulling the sample water?
    How does your water look? Do you have any debris in the pool?
    CYA test results are normally in increments of 10ppm. (40, 40, 80, etc.) How did you get 48?
    Butterfly's Avatar
    South Carolina
    10,045
    Did you have the pump running for at least an hour before you took your water sample?
    Also remember to warm the water sample to room temp for the CYA test.
    (dang, Dave, you're typing faster )
    You're done SLAMing when:
    Aug 2009
    SW Wisconsin
    518
    nope...I am topping off the pool yet..so water isn't up to skimmer level yet. There is some small debris in the pool water left over from the fall closing..but otherwise water is clear. I plan on starting the pump and filter tomorrow once water level is topped up
    and and for CYA the level wasn't at 40 and it was just under 50...so I called it 48
    Dan
    30,424
    I got it. So your CYA will be reduced somewhat as you fill, TA, CH and pH should be the same...more or less.
    I'd put enough FC in the pool tomorrow AM to get to around 6-8ppm. That's just a tad over maintenance but will give the FC a chance to kill of anything that might be hanging around in the pool without getting to low.
    Sounds like you're off to a trouble free start!
    Aug 2009
    SW Wisconsin
    518
    AWESOME
    I'll add some 6% bleach tomorrow to get it up to 6-8ppm and I'll recheck the FC tomorrow night and see where we set.
    Can't wait to get our pool open for the season. Our kids are a bout dying that we don't have it open yet..but like I said, May has just been horrible weather wise, and I didn't want anymore $500 gas bills for running our heater so much
    Dan
