Thread: How much chlorine if inceasing my cya?
    Apr 2010
    Central NJ
    227
    I'm increasing my cya from 20 to 50, and from what I've read it could take a few days for the cya to register. In the meantime, what should my chlorine target be? Should it be for a cya of 20, 50 or what ever the cya test results are?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How much chlorine if inceasing my cya?
    24 hours after your CYA dissolves, assume it is there and increase FC accordingly.
    You're done SLAMing when:
