Results 1 to 12 of 12
Thread: help please
    May 2011
    Mocksville. NC
    6
    help please
    wow there is so much info on here I am really overwhelmed. I am wanting to convert my pool- it is uncovered and top water clear bottom full of algae. Used test strips and it measures no baquacil- algistat or sanitizer- where should I start now????? Vacuum first or start dumping bleach I checked out the calculator but I am lost. Any help would be greatly appreciated. Thanks
    27' Round, AG, vinyl, 17,100 gallon,Sand filter, Baqua Pure pump 2.5 HP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: help please
    http://www.troublefreepool.com/pool-...ine_conversion is where you should start. The good test kit is not optional for this. Do it right, or don't do it at all, because otherwise you'll be stuck in technicolor slime with an unswimmable pool all summer long.
    If there's a bunch of leaves and branches in the bottom, get them out first. They'll just consume chlorine you'd rather have oxidizing bacquacil.
    If, indeed, you have no detectable bacquacil, your conversion will go real fast!
    But take pictures anyway. We love to see the colors.
    May 2011
    Mocksville. NC
    6
    Re: help please
    thanks for the reply no branches or leaves we just uncovered its just algea slime.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: help please
    Hi gretchen,
    After reading the article that Richard linked, if you have questions, please let us know.
    Welcome to the forum!
    You're done SLAMing when:
    May 2011
    Mocksville. NC
    6
    Re: help please
    I've read the article- so today I am going to the local pool store and pick up a test kit then I guess I will test the water enter in my info on the calculator and then see how much bleach I need to put in the pool, am understanding it right?
    22,539
    Re: help please
    Be sure the kit you get has the FAS-DPD chlorine test and not just the DPD test. A lot of people try to buy the kit from a pool store and are sold the DPD kit because the pool store tells them it's the same. Trust us, it's NOT! Don't be fooled.
    May 2011
    Mocksville. NC
    6
    Re: help please
    thanks for the tip- I am trying to write all this down I am still so nervous about doing this. I have almost talked myself out of converting but can't afford not to change over.
    22,539
    Re: help please
    It's all pretty intimidating at first but once you get going it is a lot easier than you think. And we're always here to help.
    30,401
    Re: help please
    Don't sweat it. Folks here on the forum will help you every step of the way....just ask.
    Also, even though I have an agenda, it is REALLY important you have that FAS/DPD kit to do your conversion.....everything else is a very poor substitute.
    Choose either the Taylor K-2006 (NOT the K-2005!!), Leslie's FAS/DPD kit, or TFTestkits TF-100
    May 2011
    Mocksville. NC
    6
    Re: help please
    thanks
    May 2011
    Mocksville. NC
    6
    Re: help please
    saw on one of the threads you can buy higher concentration bleach at pool store is this ok?
    22,539
    Re: help please
    Absolutely, sometimes it's even cheaper than the 6% you get at the big box stores.
