Results 1 to 7 of 7
Thread: How is this possible?
    Oct 2010
    Houston, TX
    152
    Ok, a relative built a 40K pool in Mexico (note: hot, sunny). There is no filtration system; it is drained and refilled once every two months or so. He vacuums it occasionally (once every several weeks) using a siphon action that draws some water out as he vacuums. The only thing he tests is pH and chlorine levels.
    The pH stays right at 7.6 without any maintenance.
    Here's the kicker: he says he adds around 2 cups of granular chlorine once every 4 weeks or so and the FC remains at above 2ppm. And it's in the hot Mexican sun all day. I've been to his pool a couple of times; it is clear and NOT green.
    Is there something I'm missing? Maybe something in the water?
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    Re: How is this possible?
    If the granular chlorine is dichlor, and they are actually adding it quite a bit more often than you describe, and the fill water levels were appropriate, that could maybe work. But as described, simply not possible.
    Oct 2010
    Houston, TX
    152
    That's what I thought, but he stays in Mexico for a couple of months, then leaves for a couple of months, then goes back. And only he maintains the pool. And he's not the type to lie/exaggerate, so not sure what's going on.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Gremlins.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Does he put an opaque cover on the pool, probably white to reflect the sun so as not to heat up the pool too much? If so, then the chlorine usage rate can drop to somewhat low levels when not exposed to sunlight, though 4 weeks is a bit of a stretch unless the water was cool which is unlikely during the summer.
    Oct 2010
    Houston, TX
    152
    Quote Originally Posted by chem geek
    No he doesn't. My only guess is he drains it more often than he says, but he was here in the states for the past month, so it's got to be at least a month in between.
    Doesn't make sense. Although gremlins would explain it...
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    He's not a salesman by any chance is he?
    The salesman I work with also has a pool and to hear him tell it he doesn't do anything but scoop leaves out, he never tests the pool. Then I visited with my kit as he asked me to check it for him, low and behold the pool guy shows up to do the maintenance!
    LMAO!
    To make a long story short, he has 5 patched holes in his liner (its less than 5 years old), the CYA is through the roof and he has four pucks in his skimmer. I was polite and declined to make any recommendations other than a complete drain and refill...which he most likely won't do.
    He never has to touch his pool!
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
