Results 1 to 13 of 13
Thread: Pool nowhere near
    Mar 2011
    North Carolina
    34
    Pool nowhere near
    I am gonna try using green to clean as I do want to swim soon as in 2011
    my latest num
    tc 9
    cc.5
    ph 7.5
    alk 90
    calc 110
    cya 40
    Foxx Pool Grecian 27000 gallons (vinyl liner)
    Sand Filter w/ 300 #'s of Brand New Sand 6/3/11
    30,431
    Re: Pool nowhere near
    KNW,
    Use whatever you think will help you, but your issue is you have not been using enough chlorine. When you shock the pool with chlorine, you must bring it up to the full strength suggested in the FC/CYA charts and then HOLD IT THERE by continual adding until your pool is clear.
    The picture indicates you have playing patty cake with the algae rather than hitting it with a chlorine sledgehammer.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Duraleigh pegged it. FC is nowhere near shock level for that CYA. You need to kill algae faster than it can reproduce. Soon as FC dips below shock, you're not, and all the chemicals you've put in so far have been for nothing.
    Have you read this sticky?
    Green to Clean is designed to be used when your CYA level is very high. There isn't much point in using when CYA is only 40, as it will just cost extra and runs some risks of creating additional complications.
    I recommend shocking as described in How to Shock Your Pool, in Pool School.
    Mar 2011
    North Carolina
    34
    the reason my chlorine reading is lower than shock level is green to clean needs you to start at 2.5 ppm
    I have been around 19-15 for over a week if that is not sledgehammer enuff sorry but dang walmart has cut me off
    Mar 2011
    North Carolina
    34
    Those pics are with a cellphone gonna get a camera and see if they look any better for you all
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Are you running your pump 24/7 and cleaning the filter regularly?
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Mar 2011
    North Carolina
    34
    Yes I am and now for the pictures from the camera
    they are self explanatory I think
    but if not side pics shallow pics and deep as well
    dont be mad at me just wanna get in duh deep end and play
    Mar 2011
    North Carolina
    34
    OK guys after 5 hours in complete sun and hotter than all get out I have only lost 1 ppm, so looking at my last pics that I took with a camera, do you all think I should get my shock level back up and continue with this process or use the green to clean, please I do value all your opinions, more so than the pool store.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I'm not a fan of green to clean...what is your CYA level?
    Mar 2011
    North Carolina
    34
    40 is my reading for cya
    Apr 2011
    Ottawa Canada
    10
    Color is nice now. Maintain shock and let the filter do its job. Gonna take a few days to clear.
    20x40 IGP Vinyl, 120,000L
    Hayward sand Filter
    Pentair Intelliflo (19gpm max)
    15 boxes(@4x10) of Enersol Solar Panels(S,E,W), Pentair solar controller
    AutoClear SWG, Kreepy Krawly
    Clear Vinyl Solar Cover, with solar reel, turning-your-green-swamp-back-into-a-sparking-oasis-t4147.html
    May 2011
    Clearwater, FL.
    446
    I'm no expert, But I would also stay at shock level until you end up with close to 0 CC with OFCLT.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
