Results 1 to 14 of 14
Thread: Looking for pictures of deck construction & tips
    Hey guys,
    So I want to build a 2nd stand alone deck to connect my pool to my main deck. I purchased a good book which shows the latest building techniques, but I am having trouble figuring out how to finish the header/outside joists closest to the pool side (since there is no room to finish them in the traditional way). Here is a drawing of what I want to do:
    http://dl.dropbox.com/u/231214/deck.jpg
    The yellow part is what I have to build.
    If you have any tips, pics of your joists/beam setup, I would really appreciate it!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,421
    Re: Looking for pictures of deck construction & tips
    Hi, bumping this back to page 1. Good luck on your build.
    Love TFP? Become a
    TFP Supporter!
    Thanks. It really should be a simple project, but there is so little info on building pool decks (round AGP's that is). I figured with all the talent here, I should be able to get some useful info
    Jul 2009
    Houston, Texas
    9,421
    There are a lot of nice above ground decks on the forum, it sometimes takes awhile for one of the owners to show up!
    Love TFP? Become a
    TFP Supporter!
    I would settle for blue prints showing how to properly place the posts closest to the pool
    Don't know if this is what you are looking for?
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    That's a great start, it shows how you finished the surface (which was very helpful), do you happen to have a photo of construction process? Thanks for taking the time to share!
    Jul 2009
    Houston, Texas
    9,421
    This site shows some deck plans for above ground pools.
    Love TFP? Become a
    TFP Supporter!
    I started with that site (was originally going to use those blocks), but since those plans are designed for above ground blocks, it changes everything.
    Where are you at? I designed my deck at Menards, most Big Box stores have in house programs that will show you everything you need to know.
    Here is the current progress of my deck build, it wasn't that bad to frame, just time consuming.
    24' round x 54" Tahitian (Sharkline), 1.5HP Sta-rite Pump, 22" 250lb. sand filter with Zeo-best media, Hayward H250FDN heater, Del Clear Ozonator, SWG or Rola-Chem feeder, not sure?, Trident Automatic Pool Cleaner, 100Watt Nightlighter, Underwater light show and fountain, 2" Hard Plumbed.
    Wishin Isa Swimmin!
    Here is a shot of the framing, I made each section individual, and tied them together creating a 2-ply beam between each section at which I put a 4x4 post and deck block on each end.
    I simply tied the main deck to these sections and used joist hangers (installed after, not seen in this pic). Where the skimmer is, I had to create a dropped beam to pick up the load so I could frame around the skimmer.
    Wishin Isa Swimmin!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Here is my drawing...sorry, no during construction pic...but I'll add one after
    Those are some really nice decks!
    I did try Lowes, but their software couldn't handle the curve.
