Results 1 to 7 of 7
Thread: Closing in warmer weather
    Jun 2007
    Charleston, SC
    151
    Hi Everyone,
    To preface, we live in Charleston, SC, so it doesnt get as cold as some of the other places. It is rare to have more than 4-5 nights a winter that are below 32 degrees.
    We moved into this house in December of last year, and the owner hadnt done anything to close the pool, they dont even have a cover. I just kept the pool marginally free of leaves all winter, and ran the pump when they were forecasting a night that would get below 35 here (which is rare) to keep the water moving to prevent freeze.
    I have a outlet switch that is set to turn the pump on if the temperature drops below 35, so I dont think I have to clear out any lines or use antifreeze. Is there anything I really need to do other than put a cover on it and just wait until spring?
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Many people in that situation don't even put the cover on. As long as the pump runs when it gets near freezing you will be fine.
    Riles_J's Avatar
    Nashville, TN
    218
    I would quess that most people do not close their pool in that type of climate. I live in Nashville, TN and our winters are a little harsher that you're describing and many folks around here leave their pool open over the winter. Since you have a freeze control outlet there isn't much you really need to do. I wouldn't even put a cover on it unless you have a lot of debris you are trying to keep out of the pool. Not having to put the cover on and pull it off, clean it, and store it is one of the main benefits of not winterizing.
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Jun 2007
    Charleston, SC
    151
    Cool, i think I will just hook the polaris up if i see a lot of leaves in it, otherwise ill just let it go.
    Thanks for the info!
    Mar 2007
    Raleigh, NC
    21
    I'm in Raleigh NC - and I decided I want to look at the pool all year too - so not closing it.
    Planned on running the pumps round the clock if we hit below freezing.. but a question.
    Right now I've cut them back to 6 hours a day and planned to go to 4 hours a day in another month or so.. are you guys saying you just shut off completely except for debris cleaning?
    I figured I needed to run them at least 4 hr a day to get some chlorine and movement to keep it from sliming up etc..
    Pool Size: 35’ x 26’ x 15’ x 8’Perimeter ft. = 104 Surface area = 557sq. ft. -- Trapezoid shape w/tanning ledge and water feature--Depth ~ 3.5’ - 5’ - 4’deep
    Jandy 2.7 Horsepower VSE Stealth pump -- Jandy CV340 Cartridge Filter -- Aqua Pure Salt System
    As the water gets colder you can reduce the pump run time. In the middle of the winter one hour a day will probably be enough (depending somewhat on the relative sizes of your pump and pool).
    Butterfly's Avatar
    South Carolina
    10,045
    Hey Woolfmarsh,
    We did not 'close' our pool last year. The only time we ran our pump/filter after the water went below 60 F was to vacuum the pool, once. We did put a heavy blanket and tarp over our semi-wind protected equipment, but that is all we did. Our winter maintenance was scooping some leaves every other day or so. Our pool looked beautiful all winter long. Just another tidbit to add to your decision! Hope this helps.
    Joyce
    p.s Born in Charleston, SC & live in Columbia, SC
    You're done SLAMing when:
