Results 1 to 11 of 11
Thread: Details on installing peristaltic chlorine pump
    Feb 2011
    Central Texas
    187
    I have a pump and 15 gal container on order and I am looking for details on how to install the pump. I am specifically concerned about tapping into the pvc after the heater. What size bit, tap and what fittings to buy? Do the fittings need to be made from a specific material? Any details would be appreciated.
    Thanks!
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    22,543
    Re: Details on installing peristaltic chlorine pump
    You need a 1/4" pipe tap and the corresponding drill size. The drill size is usually stamped on the shank of the tap. It takes a 7/16" drill.
    If you bought the Stenner pump it comes with all the fittings you need to hook it up.
    Feb 2011
    Central Texas
    187
    Any reason this would void a new pool warranty? I suppose I should contact the PB just in case
    22,543
    I can't imagine how it could possibly void any warranty. It's no different than installing an offline chlorinator.
    Feb 2011
    Central Texas
    187
    Talked to the PB and he said there would be no warranty issues.
    Aug 2010
    Austin, TX
    200
    Had a warranty issue with our aquacal heat pump. The repair guy was actually very complimentary and happy with how we have our chemical injection system setup. Post-heater was his key argument. He said if I still had my LQ hooked with chemicals entering before the heater he would have denied our warranty coverage. I probably could have escalated. Something to think about.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Feb 2011
    Central Texas
    187
    It is going in after the tab feeder. There is a check valve before the tab feeder.
    Feb 2011
    Central Texas
    187
    One more question. Anyone hardwiring the pump? Did you just snip the end of the cord off and wire it to the timer/relay?
    Yep, just cut the plug off, strip the wires, and connect.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Quote Originally Posted by loweran
    Yes, that is how I did mine, wired to the pool pump timer.
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (used on pool startup) | TF-100 | 2003 Sundance 850 Altamar hot tub
    Feb 2011
    Central Texas
    187
    That is what I ended up doing. Wired it to a relay in the ET8. I screwed it up at first as I wired the common to the bus bar. The GFCI did not like that. Had to pig tail it to the landscape lights that were on that breaker and we are all good.
