Results 1 to 16 of 16
Thread: Should I increase TA?
    Test Results:
    FC - 1.5
    CC - 0
    TC - 1.5
    TA - 60
    CH - 120
    CYA - 40
    pH - 7.2
    I am dumping some bleach in the pool when I finish writing this to bring it up to 6 ppm
    It appears that the recommended level of TA is 70-90+, 2.7kg Baking soda
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Re: Should I increase TA?
    Yes, it would be good if you raised TA. How does your water look?
    My water is crystal clear (I'd like to keep it that way)
    Can I just dump all the Baking soda into the water? It will easily dissolve?
    Yes, you can just dump it in, but I prefer to premix it in a bucket and then pour that in.
    I added 2.5 kg, that's all I had left. According to the Pool Calculator that should bring it up to 79 TA. I'll have to go out and grab some more Baking Soda when I re-stock my bleach supply.
    For several years I have been adding Baking Soda through the skimmer with the basket in with no problems but then I have a sand filter.
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    Baking soda is very forgiving of being added in a wide variety of ways. With some of the other chemicals it makes a much larger difference how you add them.
    I should be around 79 TA .... Should bump it up to 90, I have some more Baking Soda
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Plug your numbers into Pool Calculator. See what CSI is. Then decide if you want to add more baking soda, if you even need more, and if there's anything else that needs adjusting.
    This is off topic, but I don't think it deserves its own thread.
    I added my bleach and baking soda yesterday. Today I vacuumed the pool and OMG!!!! The water is sparkling. The heater has the water at 84 degrees and it was my first swim of the season today!
    I was admiring the water and I go thinking about shocking the pool. If I was to keep my water in balance as carefully as possible, will I ever need to shock the pool? Or is shocking something thats going to have to happen, but good pool care will decrease the number of times needed to shock each season?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Easto
    Congratulations! and where is our pic?!!!
    You can keep your pool balanced and not ever need to shock it. We have members (I used to be one ) that have never shocked their pools. Never needed to. I am sure some of them will be around to brag a little before too long!
    You're done SLAMing when:
    We just put in the pool in at the end of last summer, so we don't have any landscaping yet and the grass is a bit of a mess. This is a shot I took standing on the diving rock.
    Butterfly's Avatar
    South Carolina
    10,045
    Wow, how did I miss this pic! Your water looks absolutely fabulous!
    Thanks! Now that the pool is done I need to work on the rest of the landscaping.
    Aug 2010
    Dallas, TX
    4,052
    The only reason I had to shock my pool recently is:
    1. I went out of town for a week
    2. The Liquidator scaled on me and stopped feeding FC
    3. My buddy watching the house has no idea how to run a pool.
    Since then I have:
    1. Solved the scaling problem with borates, which has also stabilized my pH and lowered my FC use
    2. Raised CYA to 40 to also help FC use
    As of now, I do not expect to ever need to shock my pool again! (I don't close my pool for winter, keep the water balanced year round)
