Results 1 to 12 of 12
Thread: starting my conversion-will need help
    Sep 2007
    middle tennessee
    38
    ready to change over to SWG..got my Taylor test kit been reading it..i put 8 gals bleach in pool,,turned the pea green..
    took a sample today put in little square tester.addeded the 5 drops each,,colers are..lightest green and ph is 8.2 color ,darkness....then,i did the chlorine drop test,,took 2 drops=1.FC to clear water,,,,then did combine chlorine test ,added
    45 drops =22.5 CC.?? to clear water, what's it telling me ,,whats next....
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    First, you want to get the PH down to around 7.2 to 7.4, but only measure PH when FC is below 10. The best thing to lower PH is muriatic acid.
    Then you want to add chlorine to bring the FC back up to 15 from whatever you measure it at as frequently as possible. You can use my Pool Calculator, see the link in my signature, to figure out how much bleach that requires each time. Keep doing this over and over until the FC level holds overnight.
    At first the FC will go away very quickly and CC will climb very high. As you keep at it the FC level will slowly drift up and the CC level will drift down. Eventually FC will hold at 15 overnight and CC will go to zero. Then you change your filter media and you are done.
    Sep 2007
    middle tennessee
    38
    BIG THANKS,,please bear with me i am just learning all these numbers......
    and learning to read a test kit,,,,,
    any idea how much muriatic acid i need to add?,,i quess i can get it at lowes...
    and my FC took 2 drops to clear up,does that make my reading ok at 1..?
    30,419
    Pooldog,
    Welcome to the forum. Read the "Stickies" section completely. It'll answer a lot of your questions. Use Jason's calculator in any of his posts to answer all your questions as to "how much".
    Sep 2007
    middle tennessee
    38
    Need a little more help...have added 25 gallons of bleach,,cleaned gunk,filtered,ect....water not looking to bad...
    but I have a question,,,bought a taylor test kit,,and i need to make sure i'm reading the correct item..
    I put 10 ml water in test cylinder-add 1 scope of R-0870 powder,it turns pink..start adding drops
    of R-0871 clorine test liquid...its allways takes just 2 and it clears..am i doing it right to get the reading
    i need?..
    Yes, it sounds like you are doing the FC test correctly and getting a reading of 1.0. This is very reasonable for the early stages of a baquacil conversion. Most of the FC will combine with baquacil very quickly, preventing the FC level from getting very high at first. Once you get most of the baquacil out of the water by using enough chlorine, the FC level will start to go higher.
    Sep 2007
    middle tennessee
    38
    Have another Question concerning my change over,,have not had time to fool with pool for a few days,,
    what does it mean when you add your spoon of R0870 powder from your test kit to check FC
    and the water does not turn pink?
    Butterfly's Avatar
    South Carolina
    10,045
    The pink color indicates the presence of chlorine.....and your drops (to clear sample) tell you what the chlorine level is in your water. Although I have never seen the clear color after the powder, I assume it means the absence of chlorine.
    Good luck with your conversion!
    Joyce
    You're done SLAMing when:
    No color change usually means no chlorine. There can be rare exceptions however. When I get no color change after adding the R-0870 powder I like to do an OTO test (turns the sample various shades of yellow) to double check. If the water stays clear with that also then there is no chlorine. I have had contaminated samples that didn't change color after adding R-0870 but which did have chlorine and the OTO test turned yellow. I'm not sure what the contaminate was, but a second sample from the same pool in a different container tested at a reasonable FC level both times that has happened.
    Also, very very high FC levels can bleach out the R-0870. It doesn't usually stay clear when that happens, but it isn't pink either. In that case you just add more R-0870 till it turns pink.
    Sep 2007
    middle tennessee
    38
    Thanks for the replys,,,,more chlorine here i go ! 8)
    Sep 2007
    middle tennessee
    38
    my latest,,,,,,water looks GREAT,,,crystal clear and blue....anyone unsure "like me",,so far I have,,,added,,40 gallons bleach,,you must vaccum to waste a lot!!just about to get my chlorine where it needs to be,,thanks to everyone
    for the help....it works........
    Butterfly's Avatar
    South Carolina
    10,045
    Crystal clear and blue Sounds wonderful Got pix?
    Your hard work paid off. Now you can BBB and B happy.
    Congratulations.
    Joyce
