Thread: 3 way valve actuator?
    Well finally getting around to opening my pool this weekend.
    I installed Solar panels last year with a 3 way valve.
    http://www.westsidewholesale.com/1-5-pv ... tside.html
    This year I would like to add a automatic actuator to my diverter valve.
    So the panel will be on when the sun is on the panel and will switch it to bypass when the sun is supposed to be off the panel.
    With a timer.
    K HOLMES
    23 X 45 GUNNITE
    OWNER/BUILDER
    Re: 3 way valve actuator?
    That sounds like a great idea.
    The Goldline GL-235 solar controller is a good choice for automating the process. It is available in a package with the controller, actuator, and sensors for under $300.
