Results 1 to 10 of 10
Thread: Wildlife issue
    Nov 2010
    South Central Kentucky
    283
    Wildlife issue
    Discovered a dead rabbit floating in the pool this afternoon. Do I need to do anything with the water?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Wildlife issue
    I'd shock. And if you fished it out using a skimmer, leave that in to soak for an hour or so while the FC is up there.
    Nov 2010
    283
    Re: Wildlife issue
    It was in there less than 2 hours. Guess we can't swim today then?
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Wildlife issue
    I don't know about that. I hunted up the CDC guidelines, since the hazard is similar to a "fecal matter incident." Section 6.5.3.1 and 6.5.3.2 give some guidelines. They are vague about how CYA affects FC, since commercial pools don't get to use it much.
    A couple hours should kill anything the rabbit brought in with it, unless the rabbit started leaking something.
    Nov 2010
    283
    Re: Wildlife issue
    Appeared to be "intact" when I got it out. Just hate to not get to swim if everything is likely ok.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Re: Wildlife issue
    Quote Originally Posted by joshs2000ss
    Heck, I'd get in the pool. At 14K gallons if pool chlorine maintained properly the possible rabbit debris has been sanitized. Enjoy the water.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    22,548
    Re: Wildlife issue
    Just raise your FC up to shock level, wait an hour or so, and go swimming.
    renohuskerdu's Avatar
    Aug 2010
    Alsace, France
    44
    Re: Wildlife issue
    Maybe you could find out how the rabbit he did get in there on the first place! You no want another rabbit in your pool
    Pool-store refugee, Alsace France. AG 5k gal, sand filter, Brominator, pump 15 gpm (3.5 m3 / hour).
    Thanks to you guys we are switching to bleach from the supermarché!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Wildlife issue
    Quote Originally Posted by renohuskerdu
    I just want to say "Hi" and welcome you to TFP!!
    I absolutely love it when we get international members here
    Luv& Luk
    -Ted
    Ottawa, ON, Canada
    153
    Re: Wildlife issue
    Yes, it's much better in your plate than in your pool! Un petit civet de lapin?
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
