Thread: just double checking
    Hi, I have been an owner for a couple of years now (19,000 gallon, vinyl, SWG, NG heater, Intelliflo pumps). I also have a spillover spa.
    This is the first time I have opened the pool myself and I just wanted to check my assumptions with the experts here.
    Put the pool back together (jet outlets, stairs, etc) and filled with water. Added 3x 20kg bags of salt to bring it up to a salt level of 3000. Weather has been cloudy for the last few days, no sun at all, and the pool temp is at 72 degrees.
    Let it pump for two days solid while aquabot did its thing. Water is crystal clear. Once I saw the jets putting out what looks like .. atomized air? Its very fine air bubbles, not sure what that is about, did it once, hasn't done it again.
    Water testing with the taylor 2006 kit reveals the following.
    FC=2.5ppm
    PH=7.6
    TA=80PPM
    CH=200
    CYA=30ppm
    From my understanding the pool is safe to swim for but sanity purposes I need to bring CYA up to 70 minimum or I will be fighting PH. I have added 2Kg of stabilizer and I should wait a couple of days for that to stabilize. As a result of the stabilizer being added (as it dissolves) I need to closely monitor PH as it will probably drop but I can raise PH by turning on the aerators in the spa jets (or stair jets, or both). The rest of the settings look okay(ish) but FC is a little low? Also, testing CYA uses up quite a bit of the chemicals from the taylor kit, are these available separately?
    Thanks for your feedback.
    22,553
    Re: just double checking
    Bring the CYA up as you said and the FC should come up a little.
    The bubbles are most likely from the swcg as long as you're sure you don't have an air leak.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I'd say you are doing things just right!
