Thread: Venturi tee for aeration on external side of return fittings
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I'd like to add bubbles to my return jet for aeration but would prefer not to have plumbing in the pool. Does anyone know of any Venturi tees that fit on the external side of return fittings for AGPs? I found many Venturi tees but they all seem to have slip connections which could end up leaking at pressure. I'd like to find one with the proper MPT and FPT.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    22,553
    Re: Venturi tee for aeration on external side of return fitt
    Are you wanting to locate it inside or outside the pool?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Are you 'effing with me Bama?
    22,553
    Not at all, I can see it working both ways. Oops, I apparently missed the part about 'no plumbing in the pool'. Sorry.
    What's wrong with slip connections? Every glued connection is a slip connection.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I kind of just wanted to be able to unscrew the fittings and add the venturi to existing fittings without using glue.
