Thread: Draining water while opening pool
    Jul 2009
    Upstate New York
    36
    The water level is too high and I'm just about to super chlorinate. Do I backwash first to my desired level or do I superchlorinate first? My main concern is sending all that dirt and algae through the other end of the sand filter.
    20,000 gal oval IG, vinyl liner. 1 HP Pentair Superflo pump. Intellichlor ic20 SWCG with easy touch, Sand Dollar SD80 sand filter, Taylor K-2006 test kit.
    22,551
    Re: Draining water while opening pool
    I'd drain first if my only reason was to lower the water level. But, if there is stuff in the bottom that I needed to vacuum out, I'd use the waste function of the multiport and vacuum as much as I could out while lowering the level. The 'two birds one stone' thing...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Super chlorinate = shock.
    Apr 2009
    Burlington, ON, Canada
    344
    +1 on what Bama Rambler said. I vacuum on waste if I have to lower the water level....
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
