Results 1 to 8 of 8
Thread: New Test Results Next step is...?
    Mar 2011
    Grand Rapids, Michigan
    279
    FC 18
    CC .5
    TA 130
    PH 7.5
    CH 190
    CYA 40
    Water looks pretty darn good compared to last week when I opened it to a bunch of gray sludge resting on the bottom. Is this what one would call mustard algae? I vac'd most all of it out and the filter caught most of what got suspended. Just a bit more vac'ing to do today. Should I add more chlorine to get my CC to zero? Also, after much reading in pool school I couldn't find a chlorine level where it would be safe to put down the solar blanket. Any ballpark figures out there? We're finally suppossed to get some heat & sun out here & I'd like to be able to put the solar cover down at night. Thanks all & have a good weekend!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Re: New Test Results Next step is...?
    It probably isn't mustard algae, just sludge. You should vacuum up as much of it as you can.
    CC at 0.5 or lower is fine.
    The solar cover should be fine at anything below shock level. I'd wait until FC comes down a little before putting the solar cover back on.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You can put the solar cover on at night. take it off during the day as sunlight helps destroy CCs. Using a solar while shocking may shorten it's life span but they only last about 2 seasons anyway.
    Did your FC hold overnight? IF you lose less than 1ppm overnight you can stop shocking.
    No, that doesn't sound like mustard algae.
    Jason types faster than me....
    30,431
    DebbieO,
    This post is fine for now but, as a rule, always keep your posts in one thread unless it is a completely unrelated subject. That way, anyone logging on to your thread can read your whole "story" and give you much better advice.
    Mar 2011
    279
    Thanks all and I will remember to keep my posts in the correct thread. I'll keep vac'ing & do an overnight FC loss test tonight. Thanks again.
    30,431
    Hey, Debbie,
    As a rule, I would not waste the chemistry on an OFCLT unless your water is really clear. It sounds like you will be ready soon but perhaps not tonight unless you can see the deep end bottom clearly.
    That said, we sure love selling refills!!
    Mar 2011
    279
    I CAN see the deep end & bottom very clearly. Thanks for the tip, though. I'm sure I will be ordering refills in the near future and I absolutely love my TF100 kit. I never would have ordered one if it wasn't for TFP being there to guide me through it. I wouldn't have the confidence to tackle it myself & would still be going to the pool store. BTW, the pool store told me it was OK to have CYA as high as 200. TFP is 20,000 strong and can't be wrong!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Yup...20,000 members and rapidly growing, and that doesn;t count folks who just read the forum and pool school, yet do not sign up
    Glad you have made great progress, and good riddance to the PS
