Results 1 to 13 of 13
Thread: best way to get cya in to pool?
    May 2008
    gulf coast of Texas
    166
    Need to get my CYA up...I'm noting it as 0 since I can still see the black dot and its full to the top. I just poured stabilizer into a stocking and hung it next to the return jet...but I still need to brush and shock...is this the best way to get it into the pool? I don't want to put it into the skimmer because I'll probably have to vacuum again this evening and don't want to waste it.
    Julie
    Atlantic Pool Products "Prestige" metal wall pool 18' x 48" round
    vinyl liner
    Hayward Power Flo pump
    Hayward Perflex DE Filter Model EC50AC
    22,550
    Re: best way to get cya in to pool?
    If you're likely to have to backwash the filter, then placing it in a sock/stocking in front of a return is the best way to do it. You can also massage teh sock to help it dissolve faster.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,606
    It is recommended NOT to backwash for a week after adding it.
    22,550
    The 'no backwashing' rule is more for people that put it in the skimmer. If you pour it into the skimmer and it's trapped in the filter till it dissolves and you backwash before that happens then you'll lose a good protion of it. However, if you hang it in front of a return you won't lose nearly as much if you have to backwash. Of course, not backwashing at all would be best, but you can't always help it.
    May 2008
    gulf coast of Texas
    166
    is backwashing the same as vacuuming to waste??
    Julie
    vinyl liner
    May 2008
    gulf coast of Texas
    166
    also, the sandpaper feel all around the sides of the pool are calcium buildup from over the winter months of no treatment. I was using the edge of the pool brush to scrape it in a downward motion as its all down the sides from water level to the bottom. Is there anything other than scrubbing and scraping that will loosen it?
    Julie
    vinyl liner
    No, backwashing and vacuuming to waste are different. To vacuum to waste you need to have a multi-port valve that can be set to the waste position.
    Scraping off the calcium as you describe is a good approach. You could try using a sequestrant designed for calcium to soften it up, but if scraping is working for you that is a better approach.
    May 2008
    gulf coast of Texas
    166
    there is a valve at the bottom of the DE filter that you have to unscrew...then the water rushes out with all the gooey DE..at least thats the way I've been doing it for two summers.
    Julie
    vinyl liner
    May 2008
    gulf coast of Texas
    166
    OMG>....Never have i worked so hard like I did today! I...ME....MYSELF...scraped the walls all around the 24ft pool!!!! While doing that, I had tube socks on and rubbed the bottom divots that felt slippery and brushed the bottom the best I could since I couldn't see a thing with dead algae and calcium scales floating in the water....shocked the pool tonite..running the pump/filter..have bumped twice in last 4 hrs. Will bump again at 10pm, then see if I can persuade hubby to walk across the yard after midnite to check the pressure and bump again. Plan on the family getting in first thing in the morning to walk fast around the perimeter to get the water swirling in a whirlpool motion and exit the pool. Hoping for it to mostly settle in the center, then vacuum to waste, add new DE, and keep filtering. We have about 12 kids coming tomorrow for a little pool party for a couple hours. My thinking is to use the kids to splash up a storm, and their feet should help loosen any debris still on the bottom while the filter is still running.
    Julie
    vinyl liner
    22,550
    That sounds like a good plan to me.
    May 2008
    gulf coast of Texas
    166
    OMG....its AMAZING what throwing in 13 kids into a 24' pool can do for getting the last bits of algae and scaling can do for you!!!!!! LOLOL All the splashing and foot scrubbing going on, I've already bumped my filter twice with them in it! The floor is looking GOOD!!!!! LOL
    Julie
    vinyl liner
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by julie492
    LOL You can also use those kids when you need to raise your pH!
    You're done SLAMing when:
    May 2008
    gulf coast of Texas
    166
    My stockings of stablilizer have been hanging and slowly dissolving for the last few days....they were 1/2 full. I went out a while ago and one stocking is totally empty and the other pretty close. Wonder if they were squeezing them while in there???
    Julie
    vinyl liner
