Results 1 to 17 of 17
Thread: Pentair MniMax NT problem
    Aug 2009
    Rogers, Arkansas (NW AR)
    10
    My heater won't light & I need a little help in diagnosing the problem. When trying to light I get error message E04. I've cleaned all of the orifices, & burners but it still won't light. No flame at all during the ignition sequence. Is it reasonable to believe that I need a new Ignition control module?
    21 x 41 Oval Pacific Pool built in 2005; In-ground; Vinyl; 3'/shallow, 8.5'/deep; 29,200 Gallons; Jandy 1HP FloPro; Pentair Triton II TR-100 Sand Filter; Zodiac LRZ 250 Heater; Circupool SI45 SWG; Baracuda G-3 Cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Pentair MniMax NT problem
    It does sound like a bad igniter. Hopefully one of the professional pool guys will be along to confirm or correct my opinion.
    Love TFP? Become a
    TFP Supporter!
    Oct 2010
    Georgia
    317
    Error code E04 indicates a fan failure.
    A good service tech may be your best investment at this point.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Aug 2009
    10
    Thanks for the responses. I talked to Pentair about the error code E04. Apparently, even though they refer to it as fan failure, they use it as a generic code. The guy I spoke with said that 9 times out of 10, that error code was caused by spider webs or insects in the orifices. I'm not that lucky.
    Mar 2011
    441
    When you get E04 I typically recommend the following diagnostic flow.
    1. Does the fan run?
    2. Is the fan LED on the back of the board illuminated? If no, pull the tube off the fan, and clean out the barbed fitting on the fan. If if still no suck on the tube to see if you can get the light lit. If that doesnt work you need to replace the vacuum switch/ air flow sensor.
    3. Does the igniter light? If not pull both wires off the board, and use multimeter to check for continuity. Resistance should be ~ 75 ohms.
    Go through that, and then we can go deeper.
    20X40 30,000 gallon gunite pool
    May 2011
    36
    EO4 is listed as fan failure but thats not what it means. Most of the time its the igniter, gas, or flame sensor. The vacuum switch does play a role in that but most of the time its not it. You can always jump the vacuum switch "AFTER THE FAN COMES ON" to see if thats the problem. If it fires then there you go. If not, Pull the igniter out and check gas.
    I had the E04 error on my Minimax NT model 400 DV and the inside indicator light flashing 3 times to indicate lockout with fan failure. However, it was not the fan.
    1. removed hose from fan in top of unit.. used paper clip to make sure no debris was in the nipple on the fan housing.. (it was all clear)
    2. removed other end of hose and blew air through the hose to make sure no debris was within the hose.. (it was clear too)
    3. checked ohms on pressure switch with and without vacuum to make sure switch was working correctly.. (it was functioning correctly)
    4. reinstalled switch and checked voltage during ignition cycle and verified 24 VAC when fan ran and switch closed.. (ok so fan, switch and voltage all good)
    5. check voltage on ignitor.. should be 120 VAC but nothing there..
    6. removed ignitor, closed circuit and 120 VAC was there.. so problem appears to be ignitor (nothing about the fan was an issue.. and just a waste of time troubleshooting it all!)
    7. order ignitor.. will see what happens when replacement arrives
    The ignitor is the most common culprit. When you get the new one, open the box carefully and inspect the element. Recently got two bad consecutive ones. Also, they say not to touch the element with bare hands (or at all) as the oils on your skin can lead to premature failure.
    Good luck. This heater has been a headache for me.
    35,000 gal pool, Pebble-Tec, Pentair VF pump, DE filter, Aqua Rite SWG, Pentair Minimax Heater in Southern California
    May 2014
    Chicago
    46
    I got about 70V on the igniter and the error E05. Is it an ignition module?
    When the igniter removed, it get hot red...
    in-ground 20'000 gal; AK60431 cartridge filter x 4; Pentair MiniMax NT heater
    Tagging along with my issue:
    Fan runs well
    Unit ignites for ~3 seconds and then stops
    Tries maybe 3 times and then E04
    It happens every year when I start up the pool, in the past spiderwebs were the issue. This time vacuuming and using a paper clip to clean the gas nipples did not help.
    Any advice for additional cleaning or troubleshooting?
    Thanks!
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    Just wanted to clarify: I can clearly see flames, but the unit turns itself off after ~3 sec.
    How do I troubleshoot the flame sensor? Can I use a multimeter?
    Guy
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by guydot View Post
    Clean the wire probe part of it with steel wool or a scotchbrite pad
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    I actually took the flame sensor out and it looked pretty clean.
    I suspect that I not all the burners ignite. Is there a good way to clean the burners? I already used a paper clip for the gas nipples.
    Guy
    End of story: it was a simple case of more cleaning needed.
    I went out when it got dark, so I could see the flames better. Initially, only one burner lit up. I blew some air into the unit using the cover and more burners lit. I then new that it is a simple case of clogged nipples. I then worked on the stubborn ones with a paper clip, inserting it as deep as I could into the nipple and pushing it in/out.
    Eventually - all burners lit, blue flame. Good to go.
    Guy
    Mar 2015
    Bradenton Fl
    4
    Red face Re: Pentair MniMax NT problem
    Quote Originally Posted by ron2you View Post
    I know it has been awhile since you posted your problem with your MiniMax pool heater. I have the same heater and it appears I'm having a similar problem. As a followup I was wondering if installing a new ignitor solved your problem. Also as a point of clarification when you said "removed ignitor, closed circuit and 120 VAC was there.. " how exactly did you close the circuit... as I am thinking closing a circuit on a 120 volt supply would result in a short circuit. Any clarification on this would be helpful. I have already replaced the temperature control board which was obviously defective and I was thinking that the ignition control module may be gone as well because like you I can't get the 120v reading at the ignitor terminal on the module.
    Thanks in advance for your assistance.
    ps0303's Avatar
    Jul 2011
    FL
    3,699
    Quote Originally Posted by Canadaguy1 View Post
    Check your post you did on this issue.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2016
    los angeles / CA
    1
    My Pentair MiniMax NT - problem: it give me a E05 error. Which part specifically needs to be replaced? I've already replaced the fan, the motherboard, gas line is open, don't know where the igniter switch is???, and am wit's end!!
