Results 1 to 10 of 10
Thread: CYA and low chlorine reading
    Tonight I did my readings and after a somewhat sunny day I found I had no chlorine left to register on the test. So after immediately freaking out adding some chlorine to bring the level up to about 3-4
    I ran my cya test again and found that after 1week since adding I still have 10-15 cya instead of the 40 which I dosed for. So should I wait more or write it off to old cya from the pool store and add more now?
    Also, we had recently had a bad storm which caused about 6-7 baskets of debris worth of vacuuming which we sucked over two days
    New pool up only a week
    Should I do any cleanup to my cartridge filter yet or let it be
    Would hare for too much debris to be sitting there consuming my chlorine!
    Thanks
    Dan
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    I should also note I will retest before bed now and again in the morning
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: CYA and low chlorine reading
    Quote Originally Posted by Red Shirt Ensign
    Is the CYA completely gone from the sock(s)?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Then it is time to add more CYA. Test, adjust, and test again, until it gets where you want it.
    There have been occasional reports of 50% cyanuric acid.
    The bottle called for broadcasting it into the pool so I did that via pump on high and I slowly poured it in front of the return to disperse around the pool.
    Any comments on the filter?
    30,432
    I can't tell for sure but it sounds like you are asking if the filter should be cleaned.....ABSOLUTELY if you have had that much debris collected by the pump strainer basket, your filter surely needs cleaned.
    Cleaning the filter should be done based on the pressure increase on the gauge on the filter. Clean the filter when the pressure goes up by about 6 psi from the clean filter pressure.
    I added 2 lbs. of CYA (this time the stuff I bought from DTYdirect (from an earlier thread on the board)
    Put it in the skimmer with a sock... gonna need a rock for that skimmer basket it won't stay down for anything... plus the little metal bar came out once when I pulled it during skimming and it got stuck in the tube towards the pump... had to make a big mess to get it out...
    Does the pool calculator have the ability to calculate how much borax to add to compensate for CYA loweing the PH? I went with 1 Lb.
    Mar 2007
    San Rafael, CA USA
    12,082
    I wouldn't worry about that. It gets lowered, but not by an extraordinary amount and besides, due to carbon dioxide outgassing you'd really need to test the pH anyway rather than trying to predict it. Just let things mix and when the CYA is dissolved then measure the pH. You can then put the current and target pH into The Pool Calculator and it will tell you how much Borax to add.
