Results 1 to 10 of 10
Thread: Vacuum is now only 1/2 as strong as it used to be??
    Opened pool up this year, water was easy to get crystal clear. Pump seems to be working property at 10 psi. Everything is GREAT! However, when I go to vacuum the pool, my suction seems to be only 1/2 of what is used to be. I feel the suction if I put my finger almost inside the hole of the sweeper, but I know it was much strong than this last year. Any ideas? Thanks.
    15x30 AG 48" deep Oval
    Hayward 1.5 Power Flow Max LX Pump, Hayward E Series Sand Filter
    Superior Spa (Made right here in Oklahoma) with 96 jets
    800 feet of 2 level decking around pool and spa overlooking beautiful pasture and pond.
    Our own backyard paradise
    Re: Vacuum is now only 1/2 as strong as it used to be??
    Do you have valves on the equipment pad that control where water is drawn from that might be in a different position than usual?
    22,551
    Do you have a regulator or relief on the vacuum line?
    Have you checked the hose for a pluggage?
    Yes, we have checked the hose for being plugged. My DH "reversed" the flow and it came out the sweeper part freely and pretty strong. No, we do not have valves on the equipment pad - it only draws from one place, which is the skimmer.
    No regular or relief on the vacuum line either.
    Is it possible that the vacuum hose leaks a little and is letting air get into the pump? Pumps don't draw as well when there is air getting into the system.
    That is what I am wondering...if the vacuum hose may leak. The hose is about 5-6 years old. IF the hose has a leak, could we tell it easily or see it?
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by gooselover
    Sometimes you can. My sectioned hose was splitting on the ends and allowing air to enter the system. Had to replace it this year.
    Setup the hose and then go look at the pump skimmer basket, if there is obvious air in the pump you have a problem with the vacuum.
    I know for a few times, there was obvious "sucking" sounds coming from the skimmer. We replaced the ring around the skimmer and there is no sound coming from it now, but the suction or strength of the suction is still about 1/2. Truthfully, if you just put your hand flush on the sweeper, you feel nothing, you have to stick a finger up there to start to feel the suction, thus it is not picking up from the bottom very well at all!
