Thread: does pump run time affect chlorine usage?
    Oct 2010
    Houston, TX
    152
    For example, if pump run time was too short, would any organics that happened be in the pool be left there rather than filtered causing free chlorine to decline quicker?
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: does pump run time affect chlorine usage?
    You can get FC "dead spots" where the immediate area has poor or no circulation and the algae can get hold there easier.
    Generally, assuming there is at least some minimum circulation, pump run time does not affect chlorine usage very much. The debris is either in the pool or in the filter, either way it uses up chlorine. Things start to break down though when there is hardly any circulation or when large piles of debris build up on the bottom of the pool. Then algae can get started and chlorine usage will skyrocket.
