Results 1 to 10 of 10
Thread: What is the rate of PH rise due to aeration?
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    Sep 2008
    Hanover, PA
    11
    Re: What is the rate of PH rise due to aeration?
    If I had to guess it would depend on the level of aeration. (the more jets pointed at the surface, the greater the rate of increase). Of course that's just a guess.
    Vinyl In Ground 36x18 (26,500 Gal.),Jacuzzi TRICLOPS TC300. Two speed pump by Hayward (.25-1.5HP). Hayward H series gas heater (400,000 BTU)
    Depends on lots of things. Mostly on the rate of aeration and the PH & TA levels. PH and TA we can quantify, but it is difficult to describe different levels of aeration, so hard to make specific comparisons.
    Ok well I have a 1.5" pipe dropping water 3" into the pool with lots of small bubbles. I saw one post where it came up .4 in 24 hrs so was looking for a rough guide on how long I have to run the pump to see a change. Of course I can just wait and see
    7.2 PH
    130 TA
    21000 Gallon Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    As stated earlier, there are too many variables to give you a pat answer.
    What I have noticed is that there's an inverse proportion between starting level and how long it takes to drop. Going from 100 to 90 will take lots longer than going from 180 to 150. The more vigorous you agitate, the faster it drops. If I run all the output through my spa, and run the booster, it looks like the thing is boiling. And then it spills over into the pool, and you can actually see bubbles rising from 4 or 5 feet down. I've lost 30ppm TA in 5 hours before, as an extreme example. It also goes faster the lower the pH is. So if you keep adding acid to keep it down close to 7, rather than waiting for it to climb back up to 7.6 or so, you can speed things along.
    Dec 2010
    San Diego, CA
    1,137
    Richard, you lost the TA by adding acid. Aerating raises your ph back up without also raising your TA. Your post kind of makes it sound like you think it's the aeration that is lowering you TA. You're also speaking to the rate of TA decline where the OP was asking about the rate of pH rise.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    carlscan26, the concepts are all linked together. PH rise from aeration goes a lot slower when the TA is low, which is why lowering TA takes longer when TA is low.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by carlscan26
    I stand corrected.
    I guess I just lumped everything together because I test everything at the same time.
    Dec 2010
    San Diego, CA
    1,137
    Absolutely get that it is inter-related. So does Richard and his post wasn't wrong nor was I saying he was wrong, just that it was a bit confusing vis-a-vis the original question. You actually just summarized the declining rate of change quite succinctly.
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by Richard320
    I stand corrected.
    No offense meant Richard. I know you get this - you've posted about it elsewhere and you're not at your first rodeo given your experience with lowering your CH.
