Thread: Just an update on using floaters in the tropics
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    In the summer they don't supply enough chlorine to keep a pool sanitized.
    I also need to run my pools at 60ppm-80ppm CYA.....tablets in skimmer and some in floater. and 1-2 gallons of liquid chlor per week depending on pool volume....
    however better to use a salt system and run 80-100ppm of cya..
    so my idea of running tablet run pools on 20-30ppm of CYA and a floater fell apart...at least in the summer here in the tropics.. winter it can work,.,,
    Dec 2010
    San Diego, CA
    1,137
    Re: Just an update on using floaters in the tropics
    You weren't going to be able to keep a tablet run pool at 20-30 ppm CYA for very long...
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    susa's Avatar
    Oct 2010
    Deep South
    578
    Is there any reason you could not install this pump instead of using floaters?
