Results 1 to 10 of 10
Thread: Cloudy blue water
    Aug 2008
    Delaware
    45
    Cloudy blue water
    Can someone advise me on clearing up cloudy pool water.I have a beautiful shade of blue water,and am able to see the third step on both the stairs and the ladder.Still unable to see the bottom of the pool liner after a week and a half of adjustments and running the filter
    FC-5
    TC-2
    CC-(-3)
    PH-7.4
    Hardness-110
    TA-110
    CYA-90
    Salt-4490
    Thanks so much for all advice....I love this site!
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    Re: Cloudy blue water
    CC can't be negative, so there is something wrong with the FC/CC/TC results. Other than that, things look fairly good. CYA and Salt are both higher than I like to see, but I doubt they are high enough to cause any problems.
    For the cloudy water, I suggest trying to add a little DE to your sand filter. There are instructions on how to do that in Pool School.
    Aug 2008
    Delaware
    45
    Thanks for the help
    I saw somewhere that CYA should be in the 50-100 range with my SWG.....What range would you suggest?
    Susi
    Aug 2008
    Delaware
    45
    In my Taylor test kit...I subtract FC from TC (2-5) to get CC ....... Would my reading be 3 or -3?
    Seems I forgot a lot from last season
    Susi
    For a SWG, I recommend CYA between 70 and 80.
    If you are getting FC of 5 and TC of 2, something has gone wrong. TC has to be higher than or equal to FC. Maybe the TC test is just starting to bleach out. You could try doing the test again with a one to one dilution with chlorine free water.
    Aug 2008
    Delaware
    45
    Thanks so much.........So Am I safe to swim in the mean time?
    Susi
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    FC + CC = TC Looks like your CC (bad stuff) could be 3. I wouldn't swim in it myself.
    Aug 2008
    Delaware
    45
    any suggestions for the CC?
    Susi
    Apr 2010
    East Texas
    9,602
    "IF" your CC is that high-----shocking will cure it and some good sunshine helps too.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Susi - if your CC is really 3 you need to shock the pool - you should turn off the SWG and do an overnight FC loss test and see if your FC is holding. If the CC is 3 it probably isn't. Instructions are in Pool School. If you do need to shock - I recommend you drain some of the water out to lower your CYA level down to 60-70 and use liquid chlorine to shock the pool.
