Results 1 to 12 of 12
Thread: DE filter and PSI..
    DE filter and PSI..
    For the first month I had the pool, the PSI started at 20, then went up to 30 after a few days while cleaning,etc. Now I realize that it starts at like 7, then went down to 5 since yesterday. Does anyone know if something is wrong? I also notice the suction is not as good as before while vacuuming.. "Dirt Dust" is accumulating on the bottom of the pool..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    22,551
    Re: DE filter and PSI..
    It sounds like you have a suction pluggage. It may be something in the impeller.
    How do I fix that,
    Bel Air, MD 21015
    22,551
    You can take a water hose and try to flush water backwards toward the skimmer from the discharge of the pump. Sometimes that will dislodge a a pluggage. Is there any air in the pump strainer basket when it's running?
    Not following you.. Filter is running just psi went down...
    Bel Air, MD 21015
    The fact that the pressure went down means you probably have some kind of blockage in the plumbing on the suction side of the pump.
    Start by checking and cleaning the skimmer basket(s) and the pump strainer basket.
    If that doesn't work, turn the pump off, open up the pump strainer basket area, and as Bama said, try running water backwards through the inlet pipe.
    22,551
    About the only reason the filter pressure goes down AND the suction goes down is that there's a blockage in the suction line somewhere. As Jason said, clean the skimmer and pump strainer basket first.
    If the filter wasn't reassembled correctly then the pressure would go down but the suction would be the same or even increase.
    with the filter off, should I pump some water into where the suction is in the skimmer?
    Bel Air, MD 21015
    which inlet pipe are you talking about?
    Bel Air, MD 21015
    Open up the pump strainer basket and look inside. There should be an obvious pipe opening where the inlet pipe comes in at the front. You may need to remove the pump strainer basket to get at it.
    I fixed it! Thank you guys for all your help. I removed some leaves that may of been clogging up the lines..
    Bel Air, MD 21015
    22,551
    Glad you got it fixed. And thanks for letting us know.
