Thread: Coudy pool, new to site
    H, I hope someone can help me out. I have read over all of the information here on your site, and I have followed closely the chocking process. I started approximately 2 weeks ago with a green swamp of a pool. For a week, I brought my pool to shock level 3 or 4 times a day. The first 2 times with cal hypo, and from then on with 6% bleach. I have ran my filter continuously since this process started. I have a SWG also. My water is definately blue, but very very cloudy. I can only see down to the 2nd rung on the ladder. It has been that way for a week. Here are my test results from this morning.
    TC 5.5
    FC 5.0
    CC 0.5
    pH 7.2
    TA 110
    CH 170
    CY 10-15
    I added solid stabilizer 10 days ago. I am going to buy more today. My pool is AG, 17700 galloons, sand filter, 1 HP pump, with a SWG.
    Also of note, it has rained a lot this month, so much my pool overflowed and I have had to waste some water. I have backwashed my filter several times, and my PSI on the filter is now remaining steady.
    Thanks.
    17700 AG vinyl liner, sand filter, 1 HP pump, SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Coudy pool, new to site
    When you say "swamp".........have you made sure you've removed as much gunk as possible from the bottom to start? Twigs, leaves and such. All I can suggest is that you try and hold your FC to 10..whcih would be a couple of points higher than required if your CYA is 15. CYA test has a margin of error. Don't add stabilizer above 30 at this point, and shock it for that level. See the Chlorine/CYA chart in pool school. Go on the high side and have patience. You're on the right track. Welcome.............and it's YOUR site too!
    Welcome to TFP!
    Try adding a little DE to the sand filter, see this article in Pool School.
