bleach vs liq. shock
greif
Jul 5, 2010
65
hi
around here I can get 1.5gals of 6% bleach for $2.5 or 1 gal of 12.5% shock for $4. Do the numbers it looks like shock is a little cheaper, do the sock have anything in that is bad as it does not have an ingredents label
thanks
gary
It is identical except for the strength. Use it if it works out cheaper....there is nothing bad in it.
FWIW, "Shock" is a process you do to your pool and is not a product.....pool stores will usually tell you otherwise.
You can't buy "shock" but you can shock your pool. :mrgreen:
Thanks guys.
think I will go with the "shock" labeled becuase of less bottles to handle, yes kind of funny how they call the product that but it is actually a process
thanks
gary
I've seen the yellow colored "shock" that is 10% and the other 90% is "other ingredients," I know it would be bad business to put 90% water, but just to be clear there isn't usually anything other than chlorine and water, right?
greif said:
hi
thanks
gary
Where are you able to buy a gallon of 12.5% for that price??
