Results 1 to 8 of 8
Thread: bleach vs liq. shock
    hi
    around here I can get 1.5gals of 6% bleach for $2.5 or 1 gal of 12.5% shock for $4. Do the numbers it looks like shock is a little cheaper, do the sock have anything in that is bad as it does not have an ingredents label
    thanks
    gary
    thanks
    gary
    24ft x 54" aquasphere mission agp, cartridge filter, 1.5 hp hayward, TF-100, BBB method, pool install July 2010
    30,432
    Re: bleach vs liq. shock
    It is identical except for the strength. Use it if it works out cheaper....there is nothing bad in it.
    FWIW, "Shock" is a process you do to your pool and is not a product.....pool stores will usually tell you otherwise.
    You can't buy "shock" but you can shock your pool.
    Your bleach is 0.00217 per ppm*oz, while the "shock" is 0.0025 per ppm*oz, so the "shock" is more expensive.
    Thanks guys.
    think I will go with the "shock" labeled becuase of less bottles to handle, yes kind of funny how they call the product that but it is actually a process
    thanks
    gary
    thanks
    gary
    I've seen the yellow colored "shock" that is 10% and the other 90% is "other ingredients," I know it would be bad business to put 90% water, but just to be clear there isn't usually anything other than chlorine and water, right?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Aug 2010
    Dallas, TX
    4,052
    It probably is 90% water. The higher the concentration of chlorine, the shorter the half life on the shelf, so there is some validity for the lower concentrations.
    The inert ingredients are mostly water, with some salt, and a tiny bit of lye. The water and salt are harmless, and in most brands the amount of lye is so small you can ignore it.
    Quote Originally Posted by greif
    hi
    thanks
    gary
    Where are you able to buy a gallon of 12.5% for that price??
    34000 inground gunite / plaster pool 6 years old with spa. De filter system using fiber clear.
