Thread: Question about calculating my GPM
    Sep 2010
    SC Lowcountry
    54
    Pool newb here, so please excuse my newbness. I thought it would be wise to have a " reasonably accurate" idea of my GPM and target on water turns. Without getting too complicated, will I be able to calculate my GPM with my filter gauge and by adding a vacuum gauge on the pump? I've read so much on this subject my head hurts, and I'm still confused.
    Thanks
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Re: Question about calculating my GPM
    There is no real need to know your GPM, but if you want to try and figure it out, please tell us your filter pressure, your pipe size and length, how many pipe runs there are in each direction from the pool to the equipment pad, and if possible the vacuum pressure at the winterizing drain on the pump.
    Sep 2010
    SC Lowcountry
    54
    Apparently I'm even more confused than I thought. I was curious about how many times I was cycling the water in relation to pump run time (6 to 8 hrs), and thought GPM was something I needed to know.
    You can guess at your run time as a hint to how long you need to run your pump each day, but the real test is looking at the water. Run the pump a little longer than you think you need and see what the water looks like, then try a week at a shorter run time and if everything is still great try a shorter run time still.
