Results 1 to 12 of 12
Thread: First time testing - safe for kids to swim?
    Hi All -
    I'm trying to wean myself off of the $125 / month pool guy and do it myself. We've just put in a SWG and VS pump in for our old pool, so there is a lot of tinkering ahead of me. I ran the SWG in superchorinate mode for the last 24 hours, but when I came home it said low salt, so I'm not sure how long it ran (and I need more salt). Here are the results my first tests:
    28K Gallons
    FC 5
    CC 0
    TC 5
    Ph 8.2
    Acid Demand 4-5 drops
    TA 140
    CH 800 (!)
    CYA 95 (not sure I got this right, but it's close).
    I'm going to go play with the calculators, but any initial suggestions? We've got kids visiting tomorrow and they want to swim, think it's safe?
    Chris
    Florida Pool Service Guy
    15k Kidney Diamond Brite
    Hayward C-1200 Cartridge Filter
    Sta-Rite Dura-Glass 1.5hp Pump
    Pentair Rainbow 320 Chlorinator
    Heliocol Solar Panels
    joshearl's Avatar
    Apr 2011
    Northern California
    61
    From what I have learned the salt is nothing to worry about. If it is low it will just mean a bit harder water; salt should be around 2000ppm or a bit higher. Your pH, TA, and CYA seem off. Retest and report back, but you should be ok to swim. Salt content won't hurt anyone.
    25,000gal Plaster
    Pentair Nautilus NS-60 DE Filter
    Feb 2008
    Denton, TX
    5,061
    Re: First time testing - safe for kids to swim?
    If your CYA is 90 to 100, then you should have a FC closer to 7 ppm.
    Your pH is way too high at 8.2. The normal range for pH is somewhere between 7.2 and 7.8. 8.2 is hard on pool surfaces and will irritate swimmer's eyes. I would add acid to lower to 7.4. Additionally, that high pH coupled with the high CH means that your are at risk for scaling.
    You can address the CH after the kids have come and gone, but that FC should come up and your pH needs to come down. You need to be vigilant about pH control with any pool, but especially with SWCG pools as the pH is constantly trying to rise in those pools.
    Thanks! I'll get some muritaic today. How long after adding acid can one swim?
    30,431
    30 minutes will circulate it thoroughly....pump running.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,049
    Quote Originally Posted by gqueller
    If you get things mixed up well by running the pump and brushing the whole pool, I'd say by the time you've finished brushing, it's safe to swim.
    And pick up some liquid bleach, too. When those kids are done, dump enough in to get you up to 10 or so.
    Thanks all. Follow-on question, how do I measure FC above 5? I have the Leslie's pool rebranded Taylor kit, the one that gave me all the readings above.
    Leslie's sells a couple of different versions of that kit. It sounds like you have the K-2005 equivalent, which contains the DPD chlorine test, instead of the FAS-DPD chlorine test.
    You can do the chlorine test with dilution by mixing equal amounts of pool water and chlorine free water (typically distilled water) together, doing the test on that, and then multiplying the result by 2. You can also do more extreme dilutions, but you quickly lose precision. Keep in mind that the DPD test can bleach out, sometimes showing very high FC levels as if they were zero.
    Feb 2008
    Denton, TX
    5,061
    Get the FAS-DPD chlorine test kit here...
    http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    About .5 gallon of Muriatic Acid later, the ph has improved. New measurements:
    FC 7 (estimated, need the better kit)
    PH 7.6
    TA 130
    CH 730
    CYA 80
    Salt 4750
    Some of the change has to be variability on my part as I get better at the tests.
    The next step is to lower the TA down to ~ 90, and the pool school post shows the acid / aerate cycle will do it. The only thing I'm confused about is it mentions that I can use the SWG to aerate, but doesn't explain how. I could also hook up a blower to the spa air line, or build one of the sprayers, I suppose.
    It seems like what I really need to do is replace 50% of the water, but I really don't want to do that as I'm planning on getting it resurfaced at the end of the season... Plus, I just poured in > $100 in salt...
    Also, I'm noticing small bubbles coming out of my return lines. But it only seems to be when the VS pump is running @ lower speeds, but I'm really not sure about that. Any cause for concern? Could it just be picking up air from the spa air line?
    Thanks!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    If you only see the bubbles when the SWG is running that is normal, and that is what they mean by having the SWG aerate for you. The bubbles generated by the SWG will raise pH over time so check pH frequently and adjust as needed.
    Love TFP? Become a
    TFP Supporter!
    22,553
    If you're gonna replaster next season just work on keeping the pH in the low 7's and you should be fine. Even if you get a little scaling it's going to be gone next year anyway.
    If your CYA is close to 80 I wouldn't worry about it either. Your FC should be between 4 and 6 with a swcg and a CYA of 80.
    Now get out there and go swimming!
