Thread: Not producing Chlorine - Jandy Aquepure 1400
    Here's the story: Replaced filter this year because old one died. Started chlorinator and immediately got codes 172/185. After much online research (thank you all) we replaced the sensor. All the while, our local pool store told us to shock every five days so the water wouldn't turn green so we did. The sensor was replaced yesterday and no codes. We took a water sample up to the store and everything was okay enough to shock. We shocked it and then put the system to boost so that it would produce at 100%. Last night, of course, the chlorine was through the roof because we shocked it. The system was reading on and intermittently you could see the cell resting, reversing and on. This evening (24 hours later) we checked the water and 0 chlorine. Yep - zero.
    We are so thoroughly frustrated. What should we do at this point?
    Before we installed a new sensor, we also took a look at the cell and it looked fine but we cleaned it anyway (no foaming). Our pool is about 4 years old. 20,000 gallons. Never had a single problem until this year.
    What do you all suggest?
    Mandy
    20,000 gallon fiberglass inground pool * Hayward sand filter and pump * Jandy Aquapure 1400 SWG * Jandy Aqualink Control System
    Re: Not producing Chlorine - Jandy Aquepure 1400
    Start by posting a full set of water test results and describing what the water looks like.
    Jul 2007
    Suwanee, GA
    528
    Have you checked the water directly from the return, while the unit is boosting, to see if there is any trace of CL? This would let you know if the unit was making any chlorine and your pool isn't just eating it up.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
