Results 1 to 7 of 7
Thread: Spill-Less Clorox not real bleach
    I bought several gallons of Clorox that was labeled "Spill-less" in bottles that look just like Clorox. There is nothing on it that says it contains sodium hypochlorate, it says in small print it is a "patented formula," it says "not a disinfectant" and when I put some in a small fountain I have, it foamed. This was after I put two jugs in my pool.
    Does anyone know what's in this stuff?
    Chris
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    22,550
    Re: Spill-Less Clorox not real bleach
    If you mean splash-less bleach the msds lists it as 1-5% sodium hypo and up to 1% sodium hydroxide (caustic) as the hazardous ingredients. It doesn't list the inerts.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Do not use this product. It not only contains less bleach than you want, but has more lye in it so causes the pH to rise more than you want, and it has other compounds (as listed in the link in the post above) that you don't want. Though not a disaster, it's not the type of bleach you want to use for your pool. In addition to the effect on pH rise, you may find that the water foams more if you use this bleach.
    It would be nice if Clorox would more clearly label the product. It is not labelled as Bleach Alternative or something else that would indicate it is not simply sodium hypochlorite in a better bottle (which I stupidly thought it was), but "bleach" and it was right next to the fragranced bleaches at Walmart. There was no other plain Clorox there. Oh well, I have a couple of jugs for the laundry room.
    Aug 2008
    Southwest New Hampshire
    52
    Made the same mistake last week! Asked TBH to grab a half dozen jugs of generic bleach, but they only had two, so she got Clorox instead. (2 regular and 2 "Splashless". I used one of them and all of a sudden sudsy film on the water. Couldn't for the life of me determine what caused it. I thought something must have spilled on the solar blanket over the winter. The regular and Splashless are almost identical at a casual glance. When I saw the "Splashless" I originally thought it had something to do with the spout. Thought that was pretty stupid. Then I looked closer and voila. Been about a week and most of it seems to have dissipated.
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    AWJ's Avatar
    Mebane, NC
    10
    My better half snuck a jug of this in on me and I used it last night. Noticed foam this morning. Just got around to looking here. So I will gently notify her of this spill less issue and attempt to correct. Fortunately, we have some rain in the forecast so I my be able to backflush a bit tonight, check and adjust pH and put the correct bleach in.
    17x29 Lagoon Left foxpool 3' to 5'6", Vermiculite bottom braced to plan, Dolphin Tile w/ Krinkle, Floor vinyl line 28 mil pow fab, Foxxguard wall and coping, Inwall ladder - white rail, 1hp Whisper flo, TR-60 Sand Filter, 2 bottom drain and two 2" return inlet, Chlorinator, safety line and skimmer, Polaris 360 cleaner, Amerilite White, Meyco Cover, 6' radius - white rails walk in steps, 6' buddy seat, Exercise bar, 3" water hog deck drain 48'
