Thread: Projecting a budget
    Jul 2010
    Double Oak, TX
    44
    Projecting a budget
    I shifted to BBB late last fall. My CYA was so out of whack after 10 years of of tablets that I had tio drain the pool & start over. So far BBB has been a very positive experience for water maintenance.
    Now I am entering peak season. My pool stays in bright sun 80% of the day. I have 35K gallon in ground pool. I'm starting to wonder how Clorox per week I am going to use to keep my pool chlorinated. I'm using 6% Clorox I buy from Sam's. Any veterans of several seasons worth of BBB care to offer me a guesstimate of weekly Clorox use? Since early spring I have been using 3-4 gallons a week.
    Thanks
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    Re: Projecting a budget
    I also have a 35000 gallon pool that is in the sun from sun up to almost sun down. Last year I went through 2-4 182 ounce bleach jugs a week depending on bather load. I used maybe 2 gallons of muriatic all summer and that was it. Good luck!
    Kurt R
    35900 gal. 20x40 Inground, Vinyl Liner with Deep End in the Middle, Roman Stairs on Both Ends
    Sta Rite Sys 3, Hayward 1.5 Super Pump, Aqua Heat Heat Pump, Paramount in Floor, BBB
    Chlorine usage in mid summer when everything is working well should be between 1 and 2 ppm per day, often closer to 2. In your pool that works out to up to about 8 gallons of 6% bleach per week. Chlorine usage will be lower in the spring and fall, as you are seeing.
    Is that assuming no use? (0 bather load)
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    22,548
    I lose 2ppm per day average, all day sun, 2 to 6 kids/adults in the pool on a regular basis several times a week.
