Thread: Reviews of Solar Pool Covers
    Folks,
    Am thinking of buying one of these but would like to see some reviews if anyone has any links. I did splash out on a few of those disks but I don't think they work. I plopped one in the spa.....that's about 3 ft deep.....with the pump off. Then I measured the temp of the spa water and the pool water and there was no difference. It was sitting in the spa all day, didn't do anything. There were no disks in the pool at the time. Also I live in Houston, it was a hot day.
    Thanks
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
    Nov 2009
    Indialantic, FL
    323
    Re: Reviews of Solar Pool Covers
    The covers may actually inhibit heat production in the pool during the day. At least that's true in my area and I think Houston isn't much different. What they do is drastically slow down evaporation (the main heat loss mechanism) and help a bit with wind and "insulating" the surface at night from radiating the heat away into the night sky. I base this on trying the pool open in daylight/covered at night vice covered all day/night. While the tests were run for about a week each, I have to admit I didn't scientifically measure degree days, etc., so this is anecdotal evidence.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    reagan's Avatar
    May 2011
    NE Ohio
    64
    I've been searching the TFP forums for solar cover reviews as well. I saw this one at WalMart. I know we need a solar cover (our Intex 16' came with debris cover) and I don't want to spend double that and get 'pool-stored.'
    Is it better to buy a solar cover that fits inside the pool, or will this type of cover serve well enough?
    Thoughts?
    BBB/TFP/Taylor K-2006 Evangelist!
    6/13 - Installed AG Sharkline Heritage 21'x54" 11K gallons. Hayward 1660s sand filter, Hayward single-speed 1 hp pump; city water. Husband builds, I maintain.
    5/11 - Starter pool 6000-gallon Intex Ultra 16'x48" AG with standard 1500 gph 1/3 hp cartridge filter.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    The solar blankets float on top of the water, fitting in the pool to the insided edges. While they are mainly to inhibit heat loss from wind and night temps, they do actually provide some minimal heating to the top couple of inches of water. You will probably get as much or more heat to your water with the cover off IF it is sunny AND there is not wind to evaporate/carry off the heat. Regular covers like those provided with the Intex pools do provide some protection from evaporation, but I believe that the bubble texture layer provides a bit more insulation than a plain cover. There are all kinds of claims about one color or another, and even clear being better than others on the solar blankets. Some of them are SO heavy that you end up struggling so much to pull on and roll up -
    To come to the point - even the cheapest cover you can buy that fits your pool is the best cover - they all last just about the same amount of time WITH PROPER CARE because they really are essentially there to keep the heat in, not provide the main heat source for your water.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    reagan's Avatar
    May 2011
    NE Ohio
    64
    Thanks for the info, I didn't realize there was a difference between blankets/covers. Good to know!
