Thread: using a roof rake telescopic pole for pool
    Jul 2009
    Massachusetts
    188
    hi, the previous owner gave us their telescopic pole, but it has a cracked locking system, so we have had to duct tape it in the extended position (around 20 ft, i think). I've emailed Skimlite a few times about buying the appropriate piece and at first he said it was easy.. then i told him there's no way to easily remove the old pieces and then he tells me i actually have to cut off the part of the pole , etc.. seems pretty complicated for an "easy" replacement.
    We have a roof rake and i found that it is the same diameter and has the same 1/4' holes as the pool pole.. I also realized that the locking mechanism on the roof rake actually says "Swim Time" on it, which makes me think it should be fine for the pool.. was wondering if anyone tried this or had any thoughts on what I should be concerned about? it seems as sturdy as our skimlite pole.
    thanks
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: using a roof rake telescopic pole for pool
    Sounds to me like it would work.
