Thread: Hayward SwimPurePlus Flow Control Wiring
    I have the situation where the wire from the flow control back to the main unit has been pulled out of the telephone plug connector (dogs!) that connects to the main unit - such that I cannot tell which of the four connectors in the plug that the red and black wires, respectively, should connect.
    Any direction in the rewiring of the telephone plug would be appreciated. Thanks
    8500 gal gunnite pool, built in 2005. Sta-Rite PXC95 Filter, Intelliflo VSP 11018, Heliocol 350 sq. ft. Solar with Goldline GL-235 controller, Heatwave H120 Heat Pump, SwimPure T-3 SWCG.
    Re: Hayward SwimPurePlus Flow Control Wiring
    KenO,
    The SwimPurePlus is the same as the AquaRite ( Not sure about the SwimPurePlus with controls.. ) Anyways just tie the inner two wires together.
    flow-switch-vs-board-replacement-t31451.html?hilit=aquarite%20phone
    26K gal, vinyl, 1HP WhisperFlo pump, Pentair TA60 sand filter, Aquarite SWG t-15 Cell, PCC 2000 cleaner , Dolphin 4 Deluxe cleaner
