Thread: Hayward Tri-Star wiring question..
    Apr 2009
    Burlington, ON, Canada
    344
    Hi. I need a wiring expert if anyone can help. I was moving some wiring around (having a shed built over equipment pad) and I carefully took pictures of the wiring for the gas heater and marked the wires in case I forgot something. Unfortunately, when I took the wiring off the pool pump, I marked the wires, but forgot to take a pic.
    Now, I'm putting it back together, and notice there are two places to connect wires - one is marked L1 and has two electrical 'blades' to receive the connectors, the other is marked L2 and also has two 'blades'. I marked my wires T for top and B for bottom, but now I can't remember if they were on L1 or L2 or maybe both (like T on the top which is L1 and B on the bottom which is L2)
    Any electrical or wiring experts have an idea?
    *edit* Should have mentioned, Hayward Tri-star, 220V.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Hayward Tri-Star wiring question..
    One wire goes on L1, the other on L2. It doesn't matter which is which. There should also be a ground wire on a screw connection.
    There should be a diagram on the pump. I just connected my new Superpump 230v and the hot leads went to Line 1 & Line 3. There should be a number on the white plate where the spade terminals are.
    20k gal pool/spa, marc, Intellichlor SWG, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    Apr 2009
    344
    Ohm_boy, thank you. That's exactly what I was looking for. Up and running like a champ now. And yes, the ground wire is also connected.
    geomarq, thanks for the tip, but I couldn't see any wiring diagram on the pump label (and the owner's manual doesn't have any either). I'll have a closer look in case I missed it.
    Oh, and thank God for whoever invented circuit breakers.
